Need the ability to turn off or delete the count shown in parenthesis.
@The Other Joe you could use the "nuclear" option:
"Erase Content" does exactly what is says so use it carefully - and perhaps save a copy before you use the file because once you save your document after erasing content it doesn't come back….
For a "less permanent" delete I've had good luck with white boxes over text that I don't want to see.
Hope this helps. 😎
Thanks David. That's what I've been using. Doing this on 100-200 pages seem unproductive and would be nice if we had more formatting flexibility to accommodate more industries.. The "Apply to Pages" has the same effect somewhat, however since every markup has different spacing you still have to adjust to hide it on all pages. I've got a rolling list of improvements that would help in my industry 😁
@The Other Joe is the text string something that is generated by Revu as a part of your workflow, or is it part of the PDF that is provided to you from another software? Could you provided some additional background on your process?
Not sure I understand your questions. Are you familiar with the summary and generating a PDF summary in Bluebeam?
Yes, just using the standard Markups List Export PDF Summary reporting option with an Insert page break per custom column. I've got Mark Ups that are built up of multiple "Sub" Mark Ups. The "Sub" Mark Ups all consist of different options and can interchange with other "Sub" Mark Ups. This is Mark Up B12 #2 which has different Mark Ups then #1, #3, #4, etc.. There are (4) "Sub" Mark Ups that B12 #2 needs to build the complete B12 Mark Up for estimation. The full report consists of (118) pages.
Interesting. Completely different approach. At this point we export our markups to a .CSV file and process everything in Excel to assemble a file that we upload into our estimating software (B2W). We don't produce a PDF markup summary. We are a site civil contractor so our takeoffs are relatively straight forward most of the time.
If all you want is the B12 #2 part, why not run a search for that text string and apply highlight. Then you can export that summary based on that highlight. You may also have to turn on a setting in your preferences to show that comment Tools >Markup>Copy Highlighted Text into Markup Comment. Or you could just apply a count to that portion.
