When editing specifications, typically we will draw a reverse Z over paragraphs that we will need to delete, it may be a small Z to delete one paragraph or a big Z to delete the entire page. What is the best way to speed up this repetitive work?
I was thinking of creating a reverse Z shape and place in the toolchest and scale it in the Y-axis only if I need to delete multiple paragraphs, can you scale it in the Y-axis only?
The other ways that I can think of is use polyline to draw a reverse Z, but then you will need to manually move the control points and stretch it to cover multiple paragraphs.
Any thoughts and ideas?
