I'm trying to use form fields to build a document. Some of the fields need text that is rotated 90°. I realize you can't do angles like 45°, which hopefully gets fixed, but I can't even do a 90° anymore. I set it to rotate to 90°, but the text stays horizontal. Has anyone else run into this? Is there a fix or workaround?
At this point, I have to use a text box which doesn't serve well for what I'm trying to do.
