Hi,
Is it possible to create Bluebeam Spaces from Rooms that are located in a linked Revit model?
Our workflow consists of a separate MEP model with the architectural model linked into it. All Rooms are created in the architectural model.
In our MEP views, the Rooms from the linked architectural model are visible and can also be referenced in Revit. However, when creating a PDF using the Bluebeam Revit plugin, Bluebeam does not seem to create Spaces from these linked Rooms.
Is there a way to make the Bluebeam Revit plugin recognize Rooms from a linked model and automatically convert them into Spaces?
If this is not supported directly, is there a recommended workaround or workflow for MEP models where the Rooms are maintained in the architectural link?
Thanks in advance!
