Hi, does anyone know why the result checkbox is missing? I tried ticking select all and replacing it, but nothing changes.
Hi Qui
It looks like the selection checkbox column has been collapsed or hidden rather than removed. Try dragging the left edge of the Results panel a little wider, or reset the panel layout (Revu Preferences > Admin > Reset Settings) if it still doesn't appear. Also, let us know which version of Revu you're using (20 or 21), as that will help narrow down whether it's a UI issue or a version-specific bug.
Thank You
Hi Dhanush, thanks for the advice. I realize the issue is that the result is markup, and it's normal with pdf text, do we have a way to find and replace multiple markup text? I've reset the setting, and my version is 21.8.
