I use Revu for a multitude of tasks. In particular, I am asking about Layers functionality and features.
- Why is there not a one-click function to check all Layers per column (Lock, Print, Export) in the Layers tab? I use and create layers on product data sheets and change the filenames to have an extension of _Premarked. This allows for all markups and added information to have a uniform presentation and faster submittal creation. However, there are multiple files that are _Premarked that have close to 100, if not more, layers to toggle visibility on/off. Please add a one-click function, or a select all layers and apply selection function, etc. to the layers columns. This would reduce time significantly when creating submittals.
- Why doesn't the visibility of a layer stay invisible when visibility is turned off, the layer is then selected to be Locked, and the file is saved with the new Locked settings? I have been saving the forementioned _Premarked files using the above process and when I open the files again, visibility to every layer is turned back on. So the process described saves nothing! Again, this would be a real timesaver if the layers actually remained Locked with the settings that were last saved.
