Previously when using the polyline & polygon markups, while applying your markups the line would show up as transparent so you could see exactly where you are placing the control point. Now the line shows as a solid, creating guesswork when placing control points. This makes for extra work, as you have to go back and edit. My field is industrial construction, so we markup PIDs, Isometrics, GA's daily and this has caused quite the headache in the department.
We have been unable to find a setting to revert these to transparent while applying the markup. Please add a setting to adjust this. Thank you.
