PDF exports from EPLAN support "three-way jumps" for following internal hyperlinks, as described in the EPLAN docs and you can see for yourself when using SharePoint with the attached sample (go to page 236 and hover over three sections of AL1). Left jump leads to previous reference, center jump leads to parent reference, and right jump leads to next reference.
Bluebeam Revu follows the links properly, but the SharePoint method of highlighting the link area makes it much easier to different the three different parts of the three-way jumps, so one can much more easily click the desired section.
In this particular case:
Left leads to previous reference (p238 enclosure legend line 39 in this case)
Center leads to parent reference (p141 device tag list line 5th from bottom in this case)
Right leads to next reference (p217 valve drawing in this case)
