I have been using Revu for years and nothing like this has ever happened before. All I can think of that suddenly changed, is that I tried to save a test profile. I have not done much with profiles in Revu and wish I had not tried. So yesterday after I saved a test profile, the keyboard shortcut for TYPEWRITER no longer works. IT ALSO no longer works when I select the tool! The other shortcuts I have saved do work. I tried other profiles and it did not help. I tried reassigning the typewriter key but that did not help. The document I was working on has no form fields and I tried on several documents. I tried rebooting the PC. I tried restarting Revu. I tried logging in and out of Revu. I tried a "reset" of settings (after I backed them up) and when I restored them, I got an error box which says "ERROR LOADING STRUCTURE" with a big red X. Had to hit OK several times. After all of this, the typewriter function still no longer works.
It is possible that other markup commands don't work as well but I don't use that many different ones and the ones I've tried work.
ETA - am on fully updated Revu 21 and fully updated W11.
How can I get my handy, beloved typewriter command back? TIA!!!
