Has anyone had issues with "Split Count" and "Split All" not working for count measurements? They arent grayed out, I can click them but ever since the last update, they dont work anymore.
I have Bluebeam Revu x64 Complete, Version 21.9
Hi @john allen , Yes I experienced this when I read your post. I was using a blank template block (created in Bluebeam) Only this document was affected. Bluebeam support were very prompt but could only recreate on my document. After a bit of back and forth I discovered that the issue was a couple of redundant custom columns causing the issue. I deleted these & the split functions returned to normal. I was also able to add new custom columns with the functionality remaining. Now why these columns were an issue I don't know (re-importing them brought back the issue). Hope this helps you.
Thank you! Deleting my custom columns solved the issue as well!
