Hello, I would like to propose to add an option for Dashed Line Style for Cloud Markup in Bluebeam.
Dashed Line Style for Cloud Markup is supported by the PDF Standard starting from PDF version 1.5 file standard (released in 2003). Line Style is set by Border Style (BS) entry. While being cloudy or not cloudy is set separately by the Border Effect (BE) entry.
I tried to manually edit a cloud mark-up in Notepad ++, and I can confirm that Cloud with Dashed Line is properly rendered by Bluebeam, Adobe PDF and even Edge browser. Please see attached file.
However, because there is no option for Dashed Line Style for Cloud in Bluebeam, the Format Painter functionality of Bluebeam does not work on it properly. Also, trying to change the color of the manually edited cloud mark-up also changes its line-style back to solid line.
We need a cloud markup with dashed line style for hold clouds in engineering drawings, while we use solid-line cloud for revision clouds
Thank you.
