Dear Bluebeam Product Team,
I am writing as a long-tenured Bluebeam power user and construction estimating
professional. My work involves managing hundreds of millions of dollars in project
estimates annually, and Bluebeam has been a cornerstone tool in that process. It is
precisely because of my deep reliance on this software that I feel compelled to
formally document two significant workflow regressions introduced in the most
recent update — regressions that have materially impacted my daily productivity.
I have attempted to resolve these issues through your standard support channels
without success, and I am therefore escalating this directly to your product team in
the hope that these issues can be prioritized for correction.
The two issues are as follows:
Issue #1 — Recent Tools Panel: Duplicate Entries on Repeated Use
Previous behavior: When a custom tool was used multiple times, it
appeared only once in the Recent Tools panel — at the front of the list. This
allowed the panel to display a meaningful variety of recently used, distinct
tools at a glance.
Current behavior: Each individual use of a tool now creates a separate
duplicate entry in the Recent Tools panel. A tool used ten times now occupies
ten slots in the panel, effectively flooding it and eliminating visibility of other
recently used tools.
Business impact: The Recent Tools panel is now functionally unusable for
its intended purpose. My ability to quickly access a diverse set of markup
tools during live takeoff work has been significantly degraded, adding time
and friction to a high-speed workflow.
Issue #2 — Surface-to-Front via Drawing Interaction No Longer
Functions
Previous behavior: If a tool used previously could not be located in the
Recent Tools panel, a user could find the corresponding markup on the
drawing, make a minor adjustment (such as a slight drag), and that action
would surface the tool to the front of the Recent Tools panel. This served as
an essential recovery mechanism for locating tools within a crowded or
scrolled panel.
Current behavior: This behavior has been entirely removed. There is no
longer any interaction with an existing markup on the drawing that will surface
its associated tool in the Recent Tools panel.
Business impact: The loss of this feature eliminates a critical fallback for
power users who rely on the drawing itself as a reference point for tool
recovery. Combined with Issue #1, the Recent Tools workflow has been
rendered largely non-functional for experienced estimators.
I want to be clear: these are not minor cosmetic preferences. These two behaviors
represented a highly refined, efficient workflow developed over years of use. Their
removal — apparently without acknowledgment in release notes — suggests they
may have been unintentional regressions rather than deliberate design decisions. I
am hopeful that is the case, as it would make restoration significantly more
straightforward.
I respectfully request the following:
- Confirmation that these issues have been received and logged by your product
team. - A determination as to whether these are intentional changes or unintentional
regressions. - If intentional, a formal explanation of the rationale, and an evaluation of whether
a user preference toggle could restore the prior behavior. - If unintentional, a committed timeline for a corrective patch.
I am willing to participate in any beta testing, user interviews, or feedback sessions
that would help expedite resolution. I can provide screen recordings, detailed stepby-step reproduction cases, or any other documentation your team requires.
Bluebeam has earned its place as the industry standard for construction document
management. I have no desire to migrate to an alternative platform. However, the
productivity impact of these issues is significant enough that I must be candid: if
these behaviors are not restored, I will need to evaluate other options for my firm. I
do not raise this as a threat, but as honest feedback from a professional whose
livelihood depends on the efficiency of these tools.
I appreciate your attention to this matter and look forward to your response
