I recently upgraded to the latest version of Bluebeam from Version 20.3 and it is a disaster. There are 2 major problems that occur that have essentially eliminated the way that I typically do estimates.
- The recent tools button now records the same tool over and over again every time I use it. So if I use a polylength tool called "Wall Type 1" (34) times the recent tools button will record that (34) times instead of just (1) time like it used to. This essentially eliminates the purpose of the recent tools section. I never made custom tools for myself because I could essentially use the recent tools button again and again in order to get my takeoff's done. In this way I could customize every job. Now I am forced to make new tools each job. It is very rigid and get's rid of the purpose of using bluebeam for takeoff's now. Is there any way to fix this.
- The other problem is that in the old version if an tool I was using did not show up in recent tools or was removed from it for whatever reason I could just find that tool on the plan, click it, and drag it, then it would be moved to the front of my Recent Tools and I could use it as much as I want. Now I have to recreate the whole tool again in order to use it. Is there any way to fix this so that it will go back to the old version. There is no point in me continuing to use bluebeam if it locks me into the rigidity of onscreen takeoff where I have to make a new tool and save it every time.
If someone could please help I would really appreciate it. I have no idea why the developers would do this, it literally get's rid of the purpose of the Recent Tools Tab. More of a hinderance now than a help.
Thank You,
