When I select the measure functions such as length, perimeter and area the background of the drawing turns blue. This makes it very difficult to measure and hides the detail in the drawing. How do I remove the blue background?
I had the same issue - for myself, it was a viewport problem.
Once I deleted them all (they were all untitled) as per your instructions, my measurement tools were back to normal without semi opaque blue screen.
Thanks,
Yes, same here. This is when I discovered some pdfs come with viewports already set up on the whole page. Delete and all is good again..
What version of Revu are you using @Neil Petrie? This issue popped up in Revu 21.7, but appears, base on what my teammates are seeing, to have been addressed in Revu 21.8. You might want to consider installing the update.
Hope this helps. 😎
you MIGHT have a viewport. Go to your measurements panel and clear out all viewports if this is the case. You will see a list in the box about mid screen
I only say that because you said it is turning blue, otherwise go with what @David Cutler said.
Re-reading @Neil Petrie's original question I think you may be right @Doug McLean. Might also be an issue with the document being locked. Seems as if I've come across the "background turning blue" issue a few times where the documents were locked down.
Small Biz and we have BB Revu 20 still in our conference rooms because it does not require sign-in. I tried putting Revu 21 in one conference room and had it signed in with it's own account, but then there were server side issues and then login was required again. Users were confused and entered their own login for…
Some of the BB marked up PDFs I receive have shading and "draw order" out of whack to the point that I cannot read what's below the block. All of the items should come in like the "12' APPLES" unit, in orange. Any thoughts? The preferred "Order" would be with the shading at the base level and the pasted fixture block above.
we have installed the software and tried to login with "name_example.com" Account using "Bluebeam Australia Region"., But it is not allowing to login. Showing the error like below snip. But., we tried to login with "Bluebeam United States Region" and it allowed login, but the Plan is showing as "unassigned" like below…
Hello!! I have been using Bluebeam for a decent while, and anything I have trouble with I can usually sort out on my own, but I am stumped. We have a set of plans, all of which are images with a peach-coloured background. To save on ink, I need to change them to grayscale, ideally. Please see the attached screenshot. It…
On Windows, some PDF previews appear in my folders sidebar while others do not. It seems like the ones I created show a preview, but the externally generated ones don't. Is there a setting I can change to make all PDFs show a preview?
Has anyone had issues logging into Studio after upgrading to 21.9? I have a team member who can't get logged into Studio but can use everything else. Only thing he's done differently is upgrade. Thanks!
Is there anyway to customize keyboard short cuts for say the highlighter function? I would like to be able to have these for different colors.
Creating PDFS stopped working. Any ideas to fix?
I have a document that I have in Studio. If I open it on my ipad. Sign it. Save to file. Signature is not there when I open the file on my pc? Any ideas what is happening?
been getting a "file download error" on iCloud App. it wasn't an issue before but now some of the previous sessions is now not loading. it loads on desktop but not on the app. any idea what's causing the issue?
