Can we get a RECTANGLE SKETCH TO SCALE that has control point options like the text box? The text box has 8 control points that keep the shape as a rectangle regardless of what points are moved. Currently, if one of the points is moved it turns your perfectly good rectangle into a wonky Polygon. If I wanted that, I would use Polygon Sketch to Scale.
