I have a 1000MB file that I want to compress, but when I use the resize pdf tool, it only compresses 3%. Is there a real compression option to turn this file into something I can attach to an email?
In a word, no.
I would break that file down into individual pages, or at least into sections and then upload those to Studio Projects and invite whoever you were going to email them to to the Project.
thank you! we don't use Studio ;/
Taking a large file down to an option to email attach will be a big ask. You can look at the "edit" portion of the Reduce File Size and try to adjust the image values down. That will probably have the biggest impact on file reduction.
Also seen times when you simply print a new pdf. Keep everything the same, just make a new one from the one you're look at. This can often be a much smaller file size than the original.
thank you! the image editing was helpful, but I guess for this specific file it wasn't enough.. with the image reduction I was able to compress it using ilovepdf!
You really should explore it. If for nothing else that an FTP site
How do I ensure my session allows for plan review markups? I cannot sort out how to enable one of my sessions to have both the review and plan review tab.
Small Biz and we have BB Revu 20 still in our conference rooms because it does not require sign-in. I tried putting Revu 21 in one conference room and had it signed in with it's own account, but then there were server side issues and then login was required again. Users were confused and entered their own login for…
Some of the BB marked up PDFs I receive have shading and "draw order" out of whack to the point that I cannot read what's below the block. All of the items should come in like the "12' APPLES" unit, in orange. Any thoughts? The preferred "Order" would be with the shading at the base level and the pasted fixture block above.
we have installed the software and tried to login with "name_example.com" Account using "Bluebeam Australia Region"., But it is not allowing to login. Showing the error like below snip. But., we tried to login with "Bluebeam United States Region" and it allowed login, but the Plan is showing as "unassigned" like below…
Hello!! I have been using Bluebeam for a decent while, and anything I have trouble with I can usually sort out on my own, but I am stumped. We have a set of plans, all of which are images with a peach-coloured background. To save on ink, I need to change them to grayscale, ideally. Please see the attached screenshot. It…
On Windows, some PDF previews appear in my folders sidebar while others do not. It seems like the ones I created show a preview, but the externally generated ones don't. Is there a setting I can change to make all PDFs show a preview?
Has anyone had issues logging into Studio after upgrading to 21.9? I have a team member who can't get logged into Studio but can use everything else. Only thing he's done differently is upgrade. Thanks!
Is there anyway to customize keyboard short cuts for say the highlighter function? I would like to be able to have these for different colors.
Creating PDFS stopped working. Any ideas to fix?
I have a document that I have in Studio. If I open it on my ipad. Sign it. Save to file. Signature is not there when I open the file on my pc? Any ideas what is happening?
