Hello. Under hatch patterns, it'd be great to have a version of the grid pattern that is rotated 45 degrees. This is the traditional hatch pattern used for concrete masonry in architectural drawings. I normally achieve this by overlaying two objects with the diagonal patterns, but this can be cumbersome. Alternatively, being able to rotate the hatch pattern independently of the object's rotation in Properties would work and could be used for all patterns. Thank you.
