Is it possible to create an offset button (function similar in autocad) to be able to place lines at a distance from a point, for example?
For example: When calculating earthworks for a building, we calculate the soil 5m further than the outer perimeter of the building. Now I manually draw lines at 5m distance from each vertex to determine the area.
Or is this already possible?
Thanks!
