I remember seeing/hearing at Unbound that you could click on a measurement mark-up and change it to a different kind. i.e., change a polyline sketch to a volume. Is that a feature that is coming or something that is already possible?
Future tool coming with Revu Max sometime next year.
Thanks, Ken!
That sounds great Ken, will be very useful.
Probably not the right place for it, but here is another suggestion for a feature that could be helpful, for me at least. In OST you can click on a previous markup and then start a new markup with the same properties, instead of having to go back to the measurement toolbar or toolbox if you have it set up..
@Alan Smith - I suspect you are, but just in case anyone else is not, be sure to try out the Reuse Tool option, setting a default for any given tool, and also saving any given tool in properties mode so you can just click on that tool in a tool set (especially if it's in MyTools or you switch a given toolset to have the keyboard shortcuts for that wr
