Current Issue:
In Bluebeam Revu, it is currently not possible to select multiple control points (nodes) of a single area markup (such as a polygon, area, or volume) at the same time for batch editing or deletion. For large or complex areas with many control points, manually deleting or adjusting individual nodes is time-consuming and prone to errors.
Current Functionality:
- Control points can only be selected and edited one at a time.
- Multi-selection is available for entire markups (holding Shift and clicking), but not for control points within a single markup.
- There is no option to select and manipulate multiple control points within a single area markup.
User Need:
Especially when working with large area measurements or after using dynamic fill, users often need to delete or adjust many control points at once. The ability to select and edit multiple nodes simultaneously would save significant time and effort.
