I have added the checkbox from the 'FORMS' into my stamp, but when I add the stamp into the pdf, I can't check the boxes.
There is an article about creating interactive stamps. It's not too complicated once you get the hang of it, but getting started can be a bit slow. For my part, I used one of the predefined interactive stamps to adjust the design and fields to my needs instead of creating a completely new stamp from scratch.
If something didn't go as I envisioned, AI was able to help me fix the code.
https://support.bluebeam.com/revu/how-to/add-and-edit-interactive-stamps.html
We use the same arrangement for a submittal review stamp. Perhaps the same workflow applies.
Since the stamp tool applies a captured image, we have to edit the stamp for each application, changing the date, submittal (spec) section number, and edit the check boxes according to our status applied to the review, like APPROVED, APPROVED AS NOTED, REJECTED, etc.
This ensures the stamp is not editable and captures the record of our review before flattening.
So, summing up, rather than editing your stamp after placing/applying it in your PDF, edit AND SAVE the stamp before applying it.
Hi,
Were you able to add additional fields to the stamp? I'm currently working on customizing the engineering review stamp from the custom libraries, but I'm having trouble figuring out how to edit it without disabling the pop-up feature that appears when placing the stamp.
Ideally, I want the pop-up to remain active so that the reviewer can fill out the required fields immediately—without needing to edit or save the stamp beforehand.
Any guidance or suggestions would be greatly appreciated!
I am looking for the same idea.
