Hi again Adeeb, there is a way to import information from a .csv file into Bluebeam Revu's Markup List, but I am not sure if it's what you are looking for. When you use Choice Custom Columns, you can import data from Excel in .csv format. I have used this for duct work so I can create a long list of width, depth and circumference options that I can then import into Revu quickly. There are some tricks to using Subject in Choice Columns, and an easy first crack at it is to not use them so your Choices work on ALL markups, then go back and refine the choices by using Subject to learn how it works. TIP: Subject filters dont use Wildcards eg Subject is 'existing duct' or 'proposed duct' using '* duct' will not work for anything. check this out in BBU https://university.bluebeam.com/how-to-custom-columns/1743346 it does not cover import .csv so I have added this pic here
Hi Shanoc..
Thanks for your reply.. It was really helpful to understand the feature.. But the client is looking to import the complete columns and data straight away. The software they use has got additional plugin for excel import. Please check the screeshot attached. Do bluebeam has any plugins for the excel import.?
Sorry, Bluebeam does not have this feature.
I'm currently working on customizing the engineering review stamp from the custom libraries, but I'm having trouble figuring out how to edit it without disabling the pop-up feature that appears when placing the stamp. Ideally, I want the pop-up to remain active so that the reviewer can fill out the required fields…
Good Afternoon, I am new to Bluebeam. I downloaded the program and can utilize it minimally. Separately (and a month after downloading Bluebeam), my employer added me to their subscription. Adding me hasn't seemed to also add the functionality that others have access to. Does anyone know how to somehow link my current…
For some reason, I am not signed in utilizing Revu. I click the sign in button and nothing happens. If I click it quick enough, it actually will show my username for a split second and then goes back to "Sign In". I am unable to find anything. Is anyone else experiencing this issue? I noticed this issue prior to upgrading…
Good morning, I logged a ticket with support but no response yet. I cleared the registry by doing a complete uninstall of all previous versions and used the Bluebeam Cleaner Utility (but that only goes back to 21.0.3. I also ran the latest download as an administrator yet the only thing that installs is OCR and when it…
I'm having trouble stopping speech bubbles appearing beside custom symbols I've created and saved to my toolbox. These don't appear when others open the file however. Any tips on how to stop these appearing please? thanks in advance Joel PS I'm trying to attach an image but keep getting a permission error?
Hey Brains Trust, Using spaces for Takeoff. When I mark the space on a GA Drawings and copy / paste to an Elec drawing the space rotates as shown in the pics… What causes this and is there a way to stop this happening? There is no option to rotate this and its doubling work.
Ever since the (fairly) recent server "upgrade" I get disconnected from the Bluebeam servers several times a day and it's an annoyance. Is everyone else in the US having a similar experience? I came here just to post the item above, so that's the main issue I want to resolve. But it was even more annoying just getting to…
I have been using Revu to build quantity take-offs for construction estimates, I’m trying to clean up the organization and structure of the markups. I typically sort the markups by the subject, but I need to be able to re-sort the line items before I export the take-off. I can’t manually move items on the markup list up or…
is there a way to create page labels for a drawing set (ie 60-100+ pages), and then also add page numbering for sequential order (ie # prefix in front of custom page label)? it seems you can do one or the other, but not both?
In the existing Studio Project, I want to reorganize the folders without downloading them to my local drive and then uploading them back to the Studio Project. If I do that, I will lose the history of changes made to the set of drawings. Is there a way to move the folders within the Studio Project?
