is there a way to create page labels for a drawing set (ie 60-100+ pages), and then also add page numbering for sequential order (ie # prefix in front of custom page label)? it seems you can do one or the other, but not both?
@Shelby, you can do it in Headers and Footers with "Bates Number".
Just use the following settings:Number of Digits: 3 Start number: 1
@Shelby Here's how I handle it: First, add the page numbers using the "Header and Footer" tool. Once that's done, use the "Create Page Labels" feature with the "Page Region" option. Include the page number field from the header/footer when setting up the labels. There may be another way to handle it, and Id love to hear!
looking for way to add prefix, such as 001, 002, 003 within page label (sequentially, starting at any number), so not sure header/footer option will work for that numbering format
Hello! 2-part question: 1. Is there a method, after marking up plans, that I can Batch Change my scaled Dimensions from Ft-IN to IN? As I export to a workbook,I need to convert dimensions for formula use 2. Is there a better formatting or setup for markups, knowing that I will be exporting the data for take-offs? Thank you
Is there a way to take a markup and group it with a hyperlink and save it to the toolchest? I use the same graphic and hyperlink many times within a drawing set. Right now, I have been creating a new hyperlink pointing to a URL everytime. It would be a lot more efficient if I could create a markup that was grouped with…
