I have an excel sheet pre-built for takeoffs and would like to retain usage of this. How do I directly export the markup values gathered from Revu into their corresponding cells within my spreadsheet?
Can all of these takeoff values be exported from the Bluebeam comments list, @SKJLEst ?
You can use Quantity Link to connect directly to Excel but this does have its issues. The best way I find of getting information into a spreadsheet is to export the full Markup List to a CSV file then use this within Excel in one of two ways: -
Hope this helps!
