How do I share a Custom Toolbox with other users who use the same login but operate from a separate desktop?
Click the gear icon next to your toolbox then select Export.
Save the .btx file
Send the .btx file to other users.
They then just need to double-click the file to have it installed in their Bluebeam.
Thanks Carina
When the file is exported it does not hold the scale - is there anyway that this can be set and hold when sharing?
I believe tool scale is dependent on the sheet where the tools are being used. Have you tried using the exported custom tool box on a sheet where the scale was set , @APS ?
Another thing to note with your toolbox is that when you save a markup to it, it keeps the scale you created the markup. So, if you built the markup in a 1/4" = 1'-0" scale, by default it will be placed at that scale.
However, you can use the "Set Scale" to change the scale of your markups to better reflect the drawing.
Hopefully that helps!
