Please improve the Rotate function when rotating with the grip on plan. It has like a 15° resolution. Please make it more granular / smoother.
Hello,
If I understand your question correctly, you want to make a rotation at 15 degrees? This is possible if you hold down the shift key. Then any desired degrees can be determined. Without a shift key it is at 0, 45, 90 and so on.
Is this what you mean?
I think the question is the opposite - being able to rotate to any degree without it feeling like it "clicks" or "locks" at certain intervals.
If you hold down shift, you can rotate freely to much more granular angles
With me it is the other way around. the standard is free rotate and if i want to draw in 45 or 90 angles i have to use the shift key.However i dont know how to undo this option. I use mostly 45 and 90 degree angles. Is this an option in the menu perhaps?
Seeing as to how many rave reviews there AREN'T for Cloud, I wanted to come on here and list a few features that are desperately needed, and see if anyone else has insight into how the mobile version can be made as awesome as the PC version: Undo/redo button - Honestly can’t believe this is not there… dynamic editing of…
Hi all, I am posting to check if there has been any changes with support for fully independent windows when dragging tabs out. When I drag a tab away from the main window, the new window does not have the full toolbar, and minimizing one window causes both to minimize. I know I can open a new instance from the taskbar, but…
I often use Revu to combine documents into one PDF. Revu always asks if I want to save the stapler job before exiting. I never want to save the stapler job. Is there a way to stop that "Save Job before Exiting" popup from coming up?
Hi, I'm a new user and want to edit some text on an existing PDF file. Can somebody please help me on how can this be done. I can use text box to add content, but not edit the original content.
Feel like I'm losing my mind. but I save my custom column to profile but every time I bring in a new PDF it removes it. What can be causing this. I have saved my profile and custom multiple times a day
Is there any work-around to no keyboard shortcut for exporting a page region to Excel? I have made several (unsuccessful) attempts to figure out a way to pin this function to a toolbar, but this does not seem possible either. Is there a feature that I don't know about that will allow me to simply add this shortcut, or add…
Hi All, I am a site super who uses BB mainly for document management. As such I created a Set(.bex) to combine the different divisions of my project for easy access. I don't change anything on any of the documents but each time I close down BB a window pops up asking if I want to save the changes made to my Set(.bex) file.…
Is there a way to change the search engine used when I look up text from a file?
When a quantity link is set up in excel, it imports the value into the cell. It also uses the cell to the right of the link to tell us what that value is representing. example-sqft Can I stop it from talking the cell on the right? I just need the number.
In the latest update 21.7, semi-transparent or "highlight" markups are completely blocking out the content when measuring many documents. This creates more work if I have to guess a point location then remember to come back and fix it. I've been using BB for more than 10 years and the markups have always respected their…
