Can I assign a drop-down item, for example "glass inspection" to specific boxes, and "caulking" to other specific boxes?
If you are asking if it possible to auto-populate checkboxes based upon what is selected in a dropdown, then the answer is yes, but it involves javascript. See the attached sample. There is a document level script that would need to be tweaked for your use case:
var dropdown = this.getField("Dropdown"); dropdown.setAction("Keystroke", "processKeystroke(event)"); function processKeystroke(event) { if (event.changeEx === "") return; event.rc = true; var val = event.changeEx; this.getField("A").value = (val === "A+C") ? "Yes" : ""; this.getField("B").value = (val === "B+D") ? "Yes" : ""; this.getField("C").value = (val === "A+C") ? "Yes" : ""; this.getField("D").value = (val === "B+D") ? "Yes" : ""; }
