Revu doesn't have an offset feature that really works but you can use custom line styles to create a guide line to work to - not only does this work for straight lines but also basically any shape that you need to work to.
Hi all, my name is Aily, and I'm the Manager of Customer Education at Bluebeam - nice to meet you! I want to learn how you prefer to train, onboard, or up-skill your internal employees on everything Bluebeam, so I can make sure we're allocating the right resources to the right kinds of training (aka help me help you!). Ifā¦
If you've ever had to place a symbol on a drawing more than three times, you've probably wondered, "I wish I didn't have to keep clicking on the symbol every time I want to place it." I have great news for you š The Reuse Tools option keeps that tool selected for placing as many instances of a symbol as you need! There areā¦
Did you know that double-clicking a Bluebeam Revu Profile (.bpx file) automatically opens Revu and imports the profile for you? This is the quickest and easiest way to have a User import a Profile. It is a very low impact for our non-technical friends and co-workers. š It is much better than explaining how to click theā¦
I would like another option for locking that allows for a shapes dimensions to be locked, but still be able to move the shape / sketch around. An example of this would be a toggle for "dimension lock" where I could trace the outline of a building and rotate / move it around a site or property without accidentally changingā¦
I just installed version 21.4 this morning on a second work machine, and encountered the common problem of Print to Bluebeam being broken during install. I resolved the problem using the following steps (Windows 11, 64 bit). I have admin privileges, so make sure you can make such changes before starting. I can't guaranteeā¦
I know that Bluebeam makes it difficult to select a markup that is under another markupātry selecting a markup four levels deep! BUT! I ran a demo today, and a š” went off in my head. Can I make a Keyboard Shortcut from the R21.2 Hide selected markup feature and use it to quickly hide obscuring markups to get to the markupā¦
When moving a PDF file from the main BlueBeam application to another window (or second monitor), it creates a new Bluebeam tab. I would like to see it create a new separate application on my computer that I can pull up and down, as needed. Currently, if I click away on Bluebeam (with multiple tabs open on multipleā¦
While I wait for the influx of new members from the PHX/NorCal bug webinar I thought I'd ask about your experience with making custom hatches and line styles in Bluebeam (the topic of the webinar). There were some great examples of custom hatches and lines that made a lot of sense for those users. One was a civil officeā¦
Please add folders within sessions for document organization. This will make navigating to the documents within a session cleaner and easier as documents within a session can add up and be cumbersome to have to search through to find what the user is trying to open. This feature would be greatly appreciated by all. Thankā¦
When you need to take a snap of a portion of a pdf to prepare a new pdf document then it is always better to use the tool Snapshot (keyboard shortcut G) rather than taking Printscreen. By this we can avoid blurring of the snap / image.
