It would be very beneficial to be able to set the scale of each individual drawing. Many times we have overall plans at 1/16" scale but the elevations are at 1/8" scale. So when connecting plans and elevations, they don't line up.
This is excellent feedback. I will pass this along to the team.
Here is a response from the team regarding scale: " You can edit scale using the edit menu, but in auto alignment stage, we automatically scale up or down a section or elevation drawing to fit a floor plan. so user should not need to adjust scale for alignment. However, if for any reason the scale needs to change in the 3D view, you can modify it using the editing menu."
