When requesting a badge and you click submit, it keeps going back to the submit screen. I would think it should say something like thanks for your submission or ? or redirct you to the badges page? Might be a problem with the automation?
Thanks for the feedback, @Andy Krogh! This definitely seems confusing. The visibility and simply not letting members request the same badge again once submitted can be improved.
Currently, only the pop-up notifications let you know the status of the badge request in the bottom left corner of the page.
When you request a badge, you'll receive the following notification:
If you have already requested the badge, you'll receive:
We'll work on improving this experience, as well as providing more details on these pages for future requests.
We appreciate you letting us know!
@Andy Krogh @Marco - I didn't see any notification pop up when requesting a badge. In fact, i might have requested 3 times.
@Marco -I spy with my eye 👀. Definitely not the first place where I look for confirmation.
Might not the ideal location, @RJ Palis. Currently, we don't have a better workaround, but we are looking into solutions. We appreciate the feedback!
I think it'll help if the Send Request box goes away or redirects to a different page, like Home. I can see users being confused when this goes live for everyone.
