This is a very open question. But I will try to give some ideas on how I work with my clients: 1. Value management meetings: There could be some locally different names, so let's call these "meetings to reduce the cost of materials, reduce construction time, and ensure buildability." Use Studio Sessions for Live online Collaboration with all the stakeholders in the project to bring these ideas to one live space. 2. Shop drawing reviews. All the drawings must be approved by the project stakeholders before they are built. Again, Studio Sessions saves time on complex drawings and drawing packages with many, many drawings. 3. Recording As-Built drawings, as the design intent and actual build changes on site, record this on drawings in Studio Projets or via your DMS/CDE and access that through Sets.
We want try doing a Session through the design deliverables like SD, DD, CD. The Client wants the ability to hide their comments internally in the session between each other if they can, but see everyone else’s.
@Russell Padilla that sounds tricky. It would be a cool feature but in the mean time, The Client may need to markup a local copy and transfer their markups when ready to share.
https://support.bluebeam.com/articles/transfer-markups-to-another-document/
Luke makes a goos point. As far as Export Markup there is a clever workflow to use Layers with “Dont Export” ticked so the Export Markup feature will only share what they want to share. one step futher, build a ToolSet with this Layer to not share imbedded so the process is more automated.
Oh and Complete has Bulk Export for bigger projects.
Good luck.
I am trying to purchase a license but I can't because while I am trying to check out the system asks me to sign in and this leads to unknown authentication error. What is that? I want to pay money.
Is their any way to import a "standard list" of measurement items that I could use on multiple projects without having to type them each time I start a new project. I.E. is their an import function that could facilitate this need?
Hi, I am wondering if I am the only one that has this problem lately. Why veiwing and editing plan sheets the program lockes up and I can't close it nor does it work any more. I have to end task it to restart it. This has happened several times in the last two weeks. Can anyone help me figure this out?
I created a new set with a set of 7 sheets; I then did slip batch to add 4 revised sheets. I saved that set file but then deleted it because I realized that it did not match one sheet (sheet name changed), but I would still like for that one sheet to supersede the old one with the same sheet number. When I go try to create…
Hi All, I moved some .pdfs in my studio folder around and that has wreaked havoc on the revisioning of my Set. Is there a way to remove the Superseded stamp and return the individual sheets to the current revision status? Thanks ahead, Ian
I run a Mac in my construction office. It is great, but the only point of friction is Bluebeam Revu. I have run Parallels with Windows, in the past, to keep Revu on my computer but (although it shouldn't) it inevitable slows the machine a little. I am currently using a sub-standard PDF viewer with limited construction…
With Bluebeam Prime, we had to invite all of our users to the Prime portal so, as admin, we could help with Studio issues for our members. With such a process, we had to develop some material to show what the user could expect. So far with the Admin Org, I am not sensing that same steps- it seems easy enough to invite the…
Did something change in Bluebeam on December 17th? Up through December 16th, the email subject line for all of my incoming Bluebeam invites were formatted with the project file numbers, name of municipality/project, and the submission type. Starting December 17th, the subject line for all of my Bluebeam invites say "You've…
自社のユーザが海外子会社の別の会社に移籍することになりました。移籍先の海外子会社ではBluebeamを別途契約しており、ユーザにはその別途契約しているライセンスを割り当てたい場合はどのようにすれば良いでしょうか?自社でユーザのアカウントをDeactivateしてから、移籍先でライセンス割り当てしようとしたのですが、メールアドレスが既に登録されているためか、割り当てできなかったとのことです。移籍先は同じ系列会社のため、メールアドレスは同じものを使っています。
I have a client who is trying to mark up a set but is running into a situation where they can't add markups after a specific page. The prior pages are fine, but past the specific page they can't add any more. They are the only user who is having this issue, and I haven't been able to find a solution. Have I missed a…
