printer outputs a blank page 11x17 but "letter" prints fine. BB print function will not print a custom page range. please give me back the previous version.
Printer is HP MFP E786. I up dated drivers, no success.
IF you saved the previous installer, delete and reinstall.
IF you deleted the previous installer, try restoring from Windows File Explorer "previous versions" in the app's file properties.
IF neither of these approaches works, idunno….🤨
Sorry for the inconvenience, @Mike Huffman.
This is a known issue we're currently working on. If you'd like to provide our team with any additional information that may help, please feel free to submit a ticket. Thanks!
here is one of the error logs
Since the update to Bluebeam Revu 21, the preview line (rubber-band) shown while drawing polygons and polylines has become significantly thicker. This makes it difficult to see the underlying vector data and snap points during the drawing process.We have received numerous reports from users stating that this change hinders…
自社のユーザが海外子会社の別の会社に移籍することになりました。移籍先の海外子会社ではBluebeamを別途契約しており、ユーザにはその別途契約しているライセンスを割り当てたい場合はどのようにすれば良いでしょうか?自社でユーザのアカウントをDeactivateしてから、移籍先でライセンス割り当てしようとしたのですが、メールアドレスが既に登録されているためか、割り当てできなかったとのことです。移籍先は同じ系列会社のため、メールアドレスは同じものを使っています。
I have a client who is trying to mark up a set but is running into a situation where they can't add markups after a specific page. The prior pages are fine, but past the specific page they can't add any more. They are the only user who is having this issue, and I haven't been able to find a solution. Have I missed a…
Hi, support for PDF/A and all the different versions 1,2,3, a,b,u is not very common among all the different pdf-software out there. However all the more important is to have a good implementation and support for PDF/A in our best pdf-software Bluebeam-Revu and we actually need it very urgently. But PDF/A is just…
初めて投稿いたします。 BluebeamRevuの社内導入を、主に積算業務にて検討しているのですが 「こんなタブレットを使っている」「この大きさのモニターを使っている」等の 他社様がどのような環境で使用されているかをお聞きしたいです。 現在弊社では現状ノートPC1台と24インチのモニターで、 モニターの大きさを変えるかiPadの導入等を考えております よろしくお願いいたします。
Hi, I am allowed to join the Bluebeam max beta and I am about to and I am willinig to do so. So we were told to just download an install Bluebeam Revu 21.8. I am confused, how to tell I have the beta version? in other words, if I do not have the beta version, how to download it? maybe I missed the point completely. What is…
If I put text on a page (text box or typewriter) and then use the Edit Action command to make a jump to another page, it will put a lightning bolt under the bottom right corner of the text box. Is there a way to make the lightning bolt to the right of the text? I have issues when I have the text in a list format the…
It seems sometime in Dec 2025 the invites sent out from the BB Session no longer has the name of the document in the session invite. We use to see "You've been invited to Studio Session (name of session)" all we now see is "You've been invited to Studio Session" the name is no longer shown. Is this a preference? or has…
I use it a lot and would like to have it open at all times for quicker access. Even a keyboard shortcut would be nice, if there is one, please let me know. Thanks in advance, -Wes s
We generate PDF draft reports that are reviewed and marked up with traditional clouds, highlights and text boxes. The reviewer compares marked up Draft #1 to the updated Draft #2. Normally, the reviewer would split the view and use synchronize views between the documents. Does Bluebeam Revu have a system where it checks…
