Some of the consultant drawings I receive have a protected scale and when taking measurement and areas it doesn`t show up in the markup list. Also the drawing is blued out.
Is there away around this
Many thanks
Murray
I almost think we need to do a pinned post on this as locked drawings are an ongoing issue.
You can always try asking the Architect for an unlocked copy. If that doesn't work follow the steps below.
The first thing I look for is to see if they allowed the drawings to simply be unlocked. Click on the Signatures Panel and have the Properties panel open. There may be a button that says Unlock Drawings.
Failing that, open the Thumbnails panel and see if you can extract the pages. If yes, extract all to individual pages. This has never failed me in removing the lock. EVER. Simply combine them back together if you like.
Lastly, you can open the drawings in your Browser. Then Print to PDF as @Vince French suggested. This can take a while and I have had some weird things happen with fonts, but its rare. Good luck
Have you tried printing the drawing to a pdf to create a new version then working on that?
Hi Vince,
Thanks for that, I`ll try it out
Thanks Doug,
I went the route of extracting the pages and works perfectly.
Thank you for the great advice.
Regards
Murray Blanshard
I like that @Doug McLean! Not had problems with locked documents myself but I'll certainly remember that should I come across any.
I crossed out a text, however, I need to remove that cross out line (not the text). Could someone let me know how to remove the strikethrough?
I've customized the callout tool for weld mapping (O&G fabrication). I have the line, endpoint, and text box shape as I like them. My problem is, when used in drawing mode, my pre-populated text and text box size is exactly how I want it but the line endpoint and associated lines are locked in place (not ideal). If I use…
How do I select multiple mark-ups and copy them to all sheets in the PDF?
Help! I need to open AutoCAD files and can't find the basic instructions to find and install the plugin that will enable me to open, mark up, and save native dwg format files into a new pdf markup. I opened 'Administrator' but can't find the option to install a new plugin to Bluebeam. I only have Excel and Word plugins,…
I marked up a cloud in Revu and added three comments to the markup. On the web version, I can see all three comments. However, on the iPad, only two are displayed, and the first comment is not visible. Does anybody know how to display the first comment on the iPad?
I have a snapshot that I saved in my toolbox. The picture went away and the tool was grayed out, so I deleted it. The empty snapshot got onto my document while I was doing this process. I did not realize it at the time and continued marking up the document. Everything else is working properly. Now I have the grayed out…
Hi—has anyone found a way to navigate the menu bar using alt and arrow keys (or something else)? I'm currently seeing that pressing alt highlights "revu" on the left, but no key can drop it down or shift the highlight to a different menu bar option (eg document). I also notice that if alt is pressed, then a menu bar option…
CAn we export form Bluebeam to DXF. If not any way we can export the lines to be used in anlaysis software
Some of the consultant drawings I receive have a protected scale and when taking measurement and areas it doesn`t show up in the markup list. Also the drawing is blued out. Is there away around this Many thanks Murray
