Hi All,
I moved some .pdfs in my studio folder around and that has wreaked havoc on the revisioning of my Set. Is there a way to remove the Superseded stamp and return the individual sheets to the current revision status?
Thanks ahead,
Ian
the Superseded stamp comes in as a locked markup. Simply unlock it (Ctrl + Shift + L) and then you can delete it.
Thank you!!
Good afternoon, I'm dealing with plans where every page is a differant scale. When I switch the scale on a differant page, it changes qunatities for all pages. I tried using viewports but it won't show me the total rollup on the bottom of the whole project. Any ideas? Thank you!
Is there a way to view two open PDFs side-by-side, at once? If there is, I can't find it. TIA!
Does the Mark-up Tools availabilty lag after renewal?
I recently updated to the newest software and my Bluebeam has been crashing daily. Has any one else experienced this issue? Are there any resolutions to this?
I am trying to purchase a license but I can't because while I am trying to check out the system asks me to sign in and this leads to unknown authentication error. What is that? I want to pay money.
Is their any way to import a "standard list" of measurement items that I could use on multiple projects without having to type them each time I start a new project. I.E. is their an import function that could facilitate this need?
Hi, I am wondering if I am the only one that has this problem lately. Why veiwing and editing plan sheets the program lockes up and I can't close it nor does it work any more. I have to end task it to restart it. This has happened several times in the last two weeks. Can anyone help me figure this out?
I created a new set with a set of 7 sheets; I then did slip batch to add 4 revised sheets. I saved that set file but then deleted it because I realized that it did not match one sheet (sheet name changed), but I would still like for that one sheet to supersede the old one with the same sheet number. When I go try to create…
Hi All, I moved some .pdfs in my studio folder around and that has wreaked havoc on the revisioning of my Set. Is there a way to remove the Superseded stamp and return the individual sheets to the current revision status? Thanks ahead, Ian
I run a Mac in my construction office. It is great, but the only point of friction is Bluebeam Revu. I have run Parallels with Windows, in the past, to keep Revu on my computer but (although it shouldn't) it inevitable slows the machine a little. I am currently using a sub-standard PDF viewer with limited construction…
