If this is something that people are using is it possible to share some examples for inspiration?
@BTM When I worked in the field still, there were a couple ways that I would create a Dashboard type document in Bluebeam.
The fanciest is to make what Bluebeam calls a Digital Dashboard. Basically a fancy PDF with graphics that you link to resources/plans/files/sites/etc. You can link it all to a Studio Project where you keep files if you like.
I wold do it this way for a big project or one that was going to last a long time and needed a polished look.
Create a Digital Dashboard for easy file access | Bluebeam Technical Support
How to Build a Digital Project Dashboard | Built
On-Demand Webinar: Unlock the Power of Digital Dashboards | Bluebeam | Construction Software
I was usually too busy to make something fancy on a regular basis, so in those cases, I would just make a PDF with some instructions, maybe load a necessary Profile (.bpx) ot Teool Set (.btx) right into the PDF, add some text hyperlinks to the resources or to my Studio Project and then I would email it out, or attach it as a cover sheet in a Session, or load it as the first document anyone saw in my Studio Project. Way easier, but not as slick looking.
Oh yes, I made a sort of user's guide dashboard for my BB Project where we are hosting our conformed sets. It's been a big hit and a huge time saver. Those links provided above should give you all you need to know.
This is a great place and I am looking to set up a template for my teams projects. I am an architect, so this will be slightly different than on the construction end. Appreciate the links.
I've made several, and believe it or not, our Production Manager thinks they're a complete waste of time.
If you really want to have fun, create it first in PowerPoint, so much more design options, and then export to PDF. I think my favourite one is one that I designed in the Star Trek LCARS format.
I'd love to see the Star Trek one, that sounds awesome.
Holy crap this is awesome.
I love it! Mine were always more of the boring variety. Your Production Manager is mimissingssgin out man!
Doug this is sick! I have clearly been underutilizing power point to Revu for added pizzaz.
PowerPoint can do some really amazing things if you try. If you look at it closely, its set up for easy hyperlinking. The numbers on the left are actually Spec sections. The titles at the bottom is set up to match our Estimating folder structure, and a few key files. There's even a place for the date. The 548 is actually my employee number…lol Thank you both though
I've customized the callout tool for weld mapping (O&G fabrication). I have the line, endpoint, and text box shape as I like them. My problem is, when used in drawing mode, my pre-populated text and text box size is exactly how I want it but the line endpoint and associated lines are locked in place (not ideal). If I use…
How do I select multiple mark-ups and copy them to all sheets in the PDF?
Help! I need to open AutoCAD files and can't find the basic instructions to find and install the plugin that will enable me to open, mark up, and save native dwg format files into a new pdf markup. I opened 'Administrator' but can't find the option to install a new plugin to Bluebeam. I only have Excel and Word plugins,…
I marked up a cloud in Revu and added three comments to the markup. On the web version, I can see all three comments. However, on the iPad, only two are displayed, and the first comment is not visible. Does anybody know how to display the first comment on the iPad?
I have a snapshot that I saved in my toolbox. The picture went away and the tool was grayed out, so I deleted it. The empty snapshot got onto my document while I was doing this process. I did not realize it at the time and continued marking up the document. Everything else is working properly. Now I have the grayed out…
Hi—has anyone found a way to navigate the menu bar using alt and arrow keys (or something else)? I'm currently seeing that pressing alt highlights "revu" on the left, but no key can drop it down or shift the highlight to a different menu bar option (eg document). I also notice that if alt is pressed, then a menu bar option…
CAn we export form Bluebeam to DXF. If not any way we can export the lines to be used in anlaysis software
Some of the consultant drawings I receive have a protected scale and when taking measurement and areas it doesn`t show up in the markup list. Also the drawing is blued out. Is there away around this Many thanks Murray
I've been trying to find anything related to this, but all I see is default tool 'settings' but I want to change the tool, not settings of the tool. The default selected now is the pan tool but my most used tool is the select text tool and when I open a new PDF or have multiple opened and then I close one, Revu will change…
Hello, I have used the Grab feature for years and it is one of my most frequently used tools. Recently, however, when I grab from one drawing and paste into another, the file size increases from around 1 MB to 2 GB. If I switch off “Take Vector Snapshots”, it resolves the file size issue and the drawing size hardly…
