I want to export Text inside bubble from P&ID PDF to excel format so that I can easily inlist all tags to save time.is there any specific way or by scripting in bluebeam revu software?
This sounds like a request to export your markups. If you filter your makrup list for just your desired markups (this is easier if your markups have something descriptive in the subject field) then use markup>export
In this example I have two markups with text. the first one has text on three lines (carriage returns) and the second has a single line. The markup export will drop the comment field into excel. from there you can trim and polish your text as you need.
If you are asking to export exisitng content on the drawing, this is something that can be done quickly from CAD. You can likely set up something in Bluebeam to grab the existing content info but the reliability will be lower. Three lines of text in a bubble may not export together as the text layout in a PDF is not the same as the dwg file.
I've customized the callout tool for weld mapping (O&G fabrication). I have the line, endpoint, and text box shape as I like them. My problem is, when used in drawing mode, my pre-populated text and text box size is exactly how I want it but the line endpoint and associated lines are locked in place (not ideal). If I use…
How do I select multiple mark-ups and copy them to all sheets in the PDF?
Help! I need to open AutoCAD files and can't find the basic instructions to find and install the plugin that will enable me to open, mark up, and save native dwg format files into a new pdf markup. I opened 'Administrator' but can't find the option to install a new plugin to Bluebeam. I only have Excel and Word plugins,…
I marked up a cloud in Revu and added three comments to the markup. On the web version, I can see all three comments. However, on the iPad, only two are displayed, and the first comment is not visible. Does anybody know how to display the first comment on the iPad?
I have a snapshot that I saved in my toolbox. The picture went away and the tool was grayed out, so I deleted it. The empty snapshot got onto my document while I was doing this process. I did not realize it at the time and continued marking up the document. Everything else is working properly. Now I have the grayed out…
Hi—has anyone found a way to navigate the menu bar using alt and arrow keys (or something else)? I'm currently seeing that pressing alt highlights "revu" on the left, but no key can drop it down or shift the highlight to a different menu bar option (eg document). I also notice that if alt is pressed, then a menu bar option…
CAn we export form Bluebeam to DXF. If not any way we can export the lines to be used in anlaysis software
Some of the consultant drawings I receive have a protected scale and when taking measurement and areas it doesn`t show up in the markup list. Also the drawing is blued out. Is there away around this Many thanks Murray
I've been trying to find anything related to this, but all I see is default tool 'settings' but I want to change the tool, not settings of the tool. The default selected now is the pan tool but my most used tool is the select text tool and when I open a new PDF or have multiple opened and then I close one, Revu will change…
Hello, I have used the Grab feature for years and it is one of my most frequently used tools. Recently, however, when I grab from one drawing and paste into another, the file size increases from around 1 MB to 2 GB. If I switch off “Take Vector Snapshots”, it resolves the file size issue and the drawing size hardly…
