When using the find/search in a document it would be great to have it highlight using a different color than blue. Blue is very hard to see against black in a lot of test say on a 30x42" paper size. If it highlighted yellow, that would help.
*text not test
You can change the color of the highlights after they are applied.
Hi @TDvorzsak - are you referring to the blue that appears when you select an individual search result? I do agree it can be hard to see. I will zoom in first for better visibility when going through the search results and finding their location in the document. I can see the argument for a more visible option.
As @Jes Stafford mentioned, you can apply a highlight to the result(s) that defaults to yellow but can be changed.
So, perhaps a brighter selection color other than blue or yellow?
I would really love it if clicking on the search result resulted in the item being centered in the view window instead of in anchored in one of the four corners. The current behavior means I have to look in all four corners, and then drag/pan that region to the center of the screen so I can read everything around it. Please, just center it by default and save me the steps and frustration!
I agree! Some search results are extremely small and barely visible. As @Carl Werner, suggested, it would be very helpful to have an option where clicking on a search result automatically zooms in and centers the item on the screen.
Yes, the light blue is nearly impossible to see, and while I understand you can highlight it after the fact, this isn't useful for what I am typically trying to do. I want to find a specific number on a page where that number is repeated multiple times. I do not want it to highlight results with the mark-up because that takes time, and I'd have to un-highlight all the options that were not what I was looking for. Zooming and centering would work.
I agree changing the color would help. Some timke I just want to find stuff but not necessarily mark it.
Centering it would also be useful.
Fixing this would be important for me for reasons stated above. Most times it is difficult to see what was found where. The light blue is not enough of a contrast, and many times it is actually off the view screen. I have been resorting to search while zoomed into a very small area and even then I need to pan to find the result.
I would love to see a "Target" type display - 1" or 1-1/2" 30% translucent yellow circle around the blue result box?
This target would also be very useful when selecting items in your markup list
If that is not possible, at least bring the search result center view or have that as an option if it does not fit the needs of some.
I'd like to create/insert a table into Bluebeam Revu that I can edit like any other markup.
