Are you referring to these columns?
This discussion has been moved from Product Ideas to the Talk Bluebeam topic to gain more comments and visibility. However, this feedback has been recorded for our Product Team.
I would guess it to remove the "Comment Column" when toolchest items are in Detail mode. The comment column takes up valuable realestate and unable to open the Subject column wide to view easily without opening the whole tool chest very wide. @Willem Kraaij This would be a great fix.
When you click on 'Manage Tool Chest', select one of the existing Tool Chests and click 'Modify'.
From here, you can edit the name for each tool chest. You can also select the red "X" to delete the tool chest that are no longer used.
As far as the columns continuing to narrow, I do not have an answer for that. I agree with @Brent that the comments column should be removed or at least moved to the right of Label.
When working in the detailed view of the Tool Chest, I find the "Comment" column takes up too much screen space. Is there a way to hide or rearrange it? I’d like the "Label" to be more prominent instead.
This request has come up a couple of times. The answer so far has been "no" but go vote on the top link so they can see how much interest there is in this option.
@Marco M time to merge posts?
Just wondering what everyone is using in the field other than an IPad? Any Galaxy Tab, etc. users out there? If so, have you got any feedback?
I’m using Bluebeam Revu 21.8 – Complete and trying to streamline navigation in a drawing set. My goal is to auto-create hyperlinks from callouts (e.g. 5/A401) that jump directly to the referenced detail viewport, not just to the destination sheet as a whole. I understand that Bluebeam can create page-to-page links, but I’m…
Good afternoon, I'm dealing with plans where every page is a differant scale. When I switch the scale on a differant page, it changes qunatities for all pages. I tried using viewports but it won't show me the total rollup on the bottom of the whole project. Any ideas? Thank you!
Just wondering if anyone else has had this error message pop up in the last few days?
Hi, I am using Revu Complete and one of the main reasons I got it is for Batch Slip Sheeting. However, I find this feature to be very inconsistent at best. 2 main issues: The biggest problem is that every time I use it, whatever sheet is replaced, it's book mark is broken. So if I import 50 sheets, then save, those fifty…
My autofill descriptions list for the Count Subject has grown too big. When I begin to type in the Subject field of the "Count Measurement Properties" I get a list that is too big. I would like to clear this suggestion list. They are not "Subjects" that I have used in current PDF I am working on. They are the combined…
We are using the Revu version from 2015. We have yellow imbedded links in our PDFs that point to other PDFs. The only way these links work is if we have the folder where they are stored turned onto IE Mode. We want to get away from using IE Mode with Edge. Can someone help guide me through the process?
Hi all, I've recently been following the hype about working out of Bluebeam Sets as I'm looking for ways to streamline our workflow. I did have a question about viewing markups particularly when you are working with individual extracted drawing files as that seems like it gives you the best performance when working off of…
Does Bluebeam realize at least half of their customers use MDM? Did you know when you remove an app from an app store, it removes the app from all MDM devices thanks to the use of VPP Tokens? I am very glad they took such a careful approach to rolling out the new Bluebeam cloud! Now our 200 field guys have iPads they cant…
