It'd be nice to have a search bar for the emojis, rather than scrolling through the list. Just a thought.
I have the same suggestion, @RJ Palis ! This is Product Feedback for the vendor that we use :) I;'ve submitted this idea to them
Moved this over to the Community Chatter category.
Great suggestion, though. I get lost myself. 😅
Hey @RJ Palis & @Marco found this out…. it's possible already! Here you go
If you're on a Windows PC use the Windows key and . (the period symbol) to bring up a Windows emoji menu. This has a search bar and makes things much easier 🙂
You can also achieve this on a mac by using the shortcut control + command + space bar:
Now if "Big Emoji" could just start giving intuitive names to the various emojis, we'd all be a lot better off. 😉
I’m wanting to show a custom column identifier for each markup utilizing the count tool. Using the label properties this feature works for any measurement tool (area, length, radius etc…). However, it appears to be intended to work for the count tool, but the label only returns the «Custom Column» identifier. I'm attaching…
Has anyone experienced this issue after updating to version 21.6? It doesn’t happen every time, but occasionally I get a popup that prevents Bluebeam from opening. When this occurs, I’m unable to launch the application at all. Just wondering if anyone else has run into this and found a solution.
I have the Revu Complete plan. Revu is largest user of memory on my system. Right now I have 4 plans open and my memory usage is at 2,486.6 MB I seem to hover around 2,000 MB. Could there be a setting I need to change which will reduce this usage? I have some lagging in other programs. I had attemped to use Studio once to…
I have a new issue whereby every time i open Bluebeam, it creates me an additional "My Tools" chest….i now have 16 Tool chests named "My Tools"!?! They also cant be deleted so they are growing. Anyone have any ideas?
Hi, We are new to BB and just starting to setup our templates, library etc. I have seen comments on using BB for punchlists and viewed on youtube but does BB have a learning page on how to set these up properly? We do large multi storey hotel projects and ideally want a live punchlist of sorts. Thanks for your help
