In the legend, how do I control the number of decimal places? I only want to the tenth if not none. Apparently this is not a feature to control the decimals places for Legends.
This is a great suggestion, however, for the time being there is a workaround to get to your outcome. You can create a custom column of type formula, and set the expression to be equal to the real column you were using in the legend. In this case I am creating a clone of the "measurement" column which is used to drive the default "Quantity" fields in the legend. With the formula you can now control the number of decimal places to show, and then you can customize the legend to use this new column instead of the original one you were using. Hope this helps!
Peter you deserve a raise! I will call John and let him know. Much obliged.
It would be a huge time saver to have keyboard shortcuts for assigning markup statuses. Numerous workflows (e.g. QA/QC and design reviews, punch/back-check) involve multiple status changes for markups, and often times there are multiple statuses (or state models) to choose from. On large projects, with 100's if not 1,000's…
It would be great be able to see to whom and when the "alert attendee" has been done. Today you can see exactly who and when markups has been accepted but there are no info at all if a markup has been alerted to someone.
