I've recently switched companies and set up a new license for Bluebeam Revu. One tool I typically use constantly is not showing as it did previously. When I need to colorize a snapshot I clicked the Color Processing icon in the upper toolbar and it opens a dialogue box. I'm used to selecting Colorize from the Process Type dropdown but instead I now only get a dialogue box called Change Multiple Colors without an option to Colorize. What am I doing wrong?
Try this. Rt Click on the Snapshot>Change Colours In the opt dialog box, Select Colourize (second choice) Select your colour and make sure your Process Images box is checked. You can do the same thing from the Colour Processing button on the Properties Toolbar Let me know how it turns out.
That's what I'm used to doing, but the options are different now. This is what I'm seeing.
