When working in Split View with large PDF sets containing hundreds of sheets, it is very easy to lose track of which pane is currently active. Because the visual distinction between the active and inactive document tabs/panes is so subtle, I frequently click a thumbnail thinking I am controlling one window, only to accidentally change the sheet in the other window and lose my place.
Proposed Solution: Add a clear, high-contrast visual indicator to highlight the currently active window/pane in Split View. For example:
- A distinct colored border or outline around the active viewport.
- A bolder, higher-contrast highlight on the active tab bar or header.
- An optional toggle or color setting in Preferences so users can customize the visibility to match their theme (Dark or Light mode).
Thank you!
