I would like to know if it is possible while grouping to retain the dominant label name for the new group.
I am also curious is we will ever be able to get the .csv output with the parent/child relationships.
The ability to maintain the layer states, upon grouping would be another ask, but not as important.
Thanks,
Would sorting by different columns solve the issue?
I see what you're trying to do, you're creating an assembly, correct?
A much better way to do this is to create a Space. Name your Space to your Frame Number and then place your markups. The Space will act as a the Group feature, but will allow each part to be exported.
If you have too, you can create the Space in some white space, and then simply move the markups into it once they're done. You should probably add a custom Quantity column to your list as well so you can use it as a multiplier. Heck, name your Count tool to your Space and then use a little Power Query magic to do the work for you. (That's another show).
You MIGHT have to turn the Space column on in your list, but that's it.
Give it a shot, see if this is what you're trying to achieve and let us know
