As a Construction Administrator, I receive many PDFs with digital signatures. When opening some of the PDFs, the sender's signature does not appear. It only shows the signature field box. I have found that if I use the Bluebeam Print to PDF, the sender's signature then appears. I am curious what is causing this.
Thank you,
Ted
