In the subject of the email, template links can be made with possible project numbers and additional information, for example, if there is a field code on the form, it should also appear there.
Good morning, Martin.
You can create and customize the templates to function as needed. You may need to get creative with some scripting but I've seen other posts where uses have created similar solutions.
