I know thatI know that we can rotate pages and I know that we can mirror markups I am curious if we would be able to mirror an entire page with markups. Are currently use exterior elevations which are viewed from the exterior and I'm updating custom columns and would like to start to add radio buttons using JavaScript. On many of our projects the reviewer of the document would be on the inside of the building when they are making their markup comments so it would be nice so it helps them with orientation but then can be mirrored back to the exterior elevation.
Hi Bluebeam_J3d1
That would be a really useful workflow for elevation reviews. Mirroring individual markups is helpful, but being able to mirror the entire page including all markups, form fields, and their orientation would make interior-vs-exterior elevation reviews much easier. A page-level “Mirror Horizontally” option that could be toggled back and forth would be especially useful for this type of workflow.
Thank You
Let's hope this is an easy one, and a quick rollout. I need status update also.
This will depend on how you use layers in your markups. If all of the markups belong to the same layer, then simple press CTRL + A to select them all. The CTRL + G to group them all together. Then it's CTRL + ALT + H to flip them horizontally. Finally, it's CTRL + SHIFT + G to ungroup them. You can also do this if you use different layers however, the markups will end up being under just one layer when you ungroup them.
Yes this addressed how to mirror the markups, and I use the grouping in some cases, however all the layers are combined after grouping and I need to reassign them (at least a few updates ago), but still no way to mirror the page.
In the mirror page request I would anticipate all the page content (including text) to be mirrored as well, however I am looking for the to be done from the pages tab only in a global fashion.
Basically, one click and the entire sheet and all Bluebeam data is mirrored in that action.
Thanks,
