Ever needed to fill out a form that isn't fillable — no form fields, just static text on a PDF? Trying to line up a Text Box over each blank can be fiddly, and the box will reflow your text if you resize it.
The Typewriter tool is built for exactly this.
➡️ Here's how:
- Go to Tools > Markup > Typewriter, or press W.
- Click on the document where you want to start typing — no need to draw a box first.
- Type your text. Use Enter to control line breaks manually (Typewriter won't reflow them for you).
- If your rows don't quite line up with the form, adjust the Line Space setting in the Properties panel.
Rule of thumb: use Text Box when you want contained, reflowing notes and comments. Use Typewriter when you're dropping text onto a form-like layout with fixed rows.
➡️ Helpful article: Typewriter tool
📚 To learn this skill and brush up on all the ways to markup your documents, check out How to Use Markups in Bluebeam Revu on Bluebeam University.
👇 Share below!
- Do you use Typewriter mostly for filling out non-fillable forms, or something else?
- Text Box or Typewriter — which is your go-to?
