If you find yourself reaching for the same tools over and over — or reassigning the same markup properties every time — there's a faster way to work.
Revu lets you customize your own keyboard shortcuts, so the tools and commands you use most are always one keystroke away.
➡️ Here's how:
- Go to Revu > Keyboard Shortcuts.
- Select Tools or Commands at the top of the dialog box.
- Select a function, enter your new shortcut in the Shortcut field, and select Reassign.
- Select OK to save your changes.
Want to share your setup with your team, or move it to a new machine? Go to Export > Settings to save your shortcuts as an XML file, then Import it wherever you need it.
📚 To learn this skill and brush up on other ways to navigate and customize the Revu interface, check out How to Customize Keyboard Shortcuts on Bluebeam University.
Or read this article: Customize Revu keyboard shortcuts
👇 Share below! What keyboard shortcut have you created that you use regularly to save time (and clicks)?
