I am exporting my PDF from GIS Pro - which has a raster aerial and then vector polygons on top which have a transparent fill. I can view the pdf in Revu and everything looks as it should (Raster aerial and transparent vector polygons). However, when I go to reduce file size in Revu, my vector polygons get a solid fill (transparency removed). Is there a way to control this through Bluebeam Revu settings so my raster aerial gets reduced but my vector graphics do not get modified?
Attached is an example file. Thanks for any insight in advance!
