Hi
We noticed today that a new column called "GoCanvas Status" is automatically enabled in all of our profiles.
We understand that the current workaround is to uncheck the column and save the profile again. However, this becomes difficult to manage in our environment since we maintain around 30 different profiles deployed centrally.
Every time a new version is releasd, the column appears again, which means we need to update and redistribute all profiles once more. This is unfortunately not sustainable in the long run.
We believe it would be better if built-in columns such as this one were disabled by default, allowing each company to decide whether they want to enable them or not.
Could you please consider changing this behavior in your next release so that the GoCanvas Status column is unchecked by default?
Thanks in advance for taking this feedback into consideration!
